HeatPump:PlantLoop:EIR:Heating/Cooling model not heating or cooling
I have been having some problems modeling an air to water heat pump heating and cooling system in energyplus. In the model, the HeatPump:PlantLoop:EIR:Heating and HeatPump:PlantLoop:EIR:Cooling objects serve water plant loops which have been connected to a Coil:Heating:Water object and a Coil:Cooling:Water object. These coil objects then serve a AirLoopHVAC:UnitarySystem that provides hot and cold air to the zones. I have the model in a place where it seems to be autosizing properly (the HeatPump:PlantLoop:EIR have not been autosized as I understand there have been some problems with that), however the zones are not being heated or cooled when the model is run. There is also no demand for the water loops even though the hot and cold water loops are available during the correct months. I have attached a zip of the idf and other relevant files for anyone to look at.
I have been having some problems modeling an air to water heat pump heating and cooling system in energyplus. In the model, the HeatPump:PlantLoop:EIR:Heating and HeatPump:PlantLoop:EIR:Cooling objects serve water plant loops which have been connected to a Coil:Heating:Water object and a Coil:Cooling:Water object. These coil objects then serve a AirLoopHVAC:UnitarySystem that provides hot and cold air to the zones. I have the model in a place where it seems to be autosizing properly (the HeatPump:PlantLoop:EIR have not been autosized as I understand there have been some problems with that), however the zones are not being heated or cooled when the model is run. There is also no demand for the water loops even though the hot and cold water loops are available during the correct months. I have attached a zip of the idf and other relevant files for anyone to look at.link text
I have been having some problems modeling an air to water heat pump heating and cooling system in energyplus. In the model, the HeatPump:PlantLoop:EIR:Heating and HeatPump:PlantLoop:EIR:Cooling objects serve water plant loops which have been connected to a Coil:Heating:Water object and a Coil:Cooling:Water object. These coil objects then serve a AirLoopHVAC:UnitarySystem that provides hot and cold air to the zones. I have the model in a place where it seems to be autosizing properly (the HeatPump:PlantLoop:EIR have not been autosized as I understand there have been some problems with that), however the zones are not being heated or cooled when the model is run. There is also no demand for the water loops even though the hot and cold water loops are available during the correct months. I have attached a zip of the idf and other relevant files for anyone to look at.at: link textHeatPump:PlantLoop:EIR Model
I have been having some problems modeling an air to water heat pump heating and cooling system in energyplus. In the model, the HeatPump:PlantLoop:EIR:Heating and HeatPump:PlantLoop:EIR:Cooling objects serve water plant loops which have been connected to a Coil:Heating:Water object and a Coil:Cooling:Water object. These coil objects then serve a AirLoopHVAC:UnitarySystem that provides hot and cold air to the zones. I have the model in a place where it seems to be autosizing properly (the HeatPump:PlantLoop:EIR have not been autosized as I understand there have been some problems with that), however the zones are not being heated or cooled when the model is run. There is also no demand for the water loops even though the hot and cold water loops are available during the correct months. I have attached a zip of the idf and other relevant files for anyone to look at: HeatPump:PlantLoop:EIR Model
