I am trying to silently install with the command --script install.qs stated in the link below:
https://nrel.github.io/OpenStudio-user-documentation/getting_started/getting_started/
It looks like it goes through but when I check control panel/Uninstall a Program and the default install location (C Drive) there is no open studio-3.2.0 folder there. I can run the app with the silent parameters but nothing happens when using the parameters. This is on a VM since I am testing locally before testing out mass deployments. Any help would be really appreciated.
Thank you
