According to the simulation about solar based vapor absorption chiller system (SVACs), I've already done the model (mock-up) by Sketchup to be used in OpenStudio. Firstly, I provided the system in 3 water sides (i.e., chilled water, cooling water and hot water). However, the results about cooling water and hot water were reasonable, but the cooling cooling energy (by chilled water side) was not shown the result. (too small of amount of electricity consumption for cooling, also cooling capacity (BTU/H).). Moreover, the chiller water temperature inlet to cooling coil (FCU) did not make sense.
The questions are : 1./ The created system was correct, wasn't it? 2./ Why the amount of cooling did not occur the result?
The attachment are as follows : 1./ SVACs system (in OpenStudio) 2./ System results
Download link : https://wetransfer.com/downloads/e21c11062bf8dcdf32f128212b8ffefc20210905100624/3b919aa363953942f7d21c80fb3bc1c420210905100644/4f12a0
Thank you in advance. Varakorn K.
