Hello everyone, I hope you are all in good health.
Currently, I don't have any inputs under "Output reporting" of the idf. And I've also selected all output controls files as : No. Still I'm getting the following lines at the end of each file run. (I'm losing some simulation time with the process corresponding to those messages appearing after my run): Requested ESO file=cs10.mtr ReadVarsESO program starting. does not exist. ReadVarsESO program terminated. ReadVarsESO program terminated. EnergyPlus Run Time=00hr 00min 39.04sec Is there a way I can overcome that ? Thanks!
