In my model, I have applied a measure named "OpenStudio Result (PH) unit". But, after applying the measure or any other measures the file couldn't save. If I try to save the file then it shows "Failed to save model, make sure that you do not have the location open and that you have correct write access". I am using OpenStudio version SDK 3.1.0. Would you please help me out to fix the problem and make a solution?
