Dear all, I'm using the OpenStudioApp 3.1.0 and try to use monitored hourly enegry values for the electric equipment. I imported them via “Add interval Schedule From File” and I see the file in "Fixed Interval Schedules". But the program does not allow to use this imported file as an profile for the Eletric Equipment. The profile is only allowed for "Other Equipment", but it doesn't work there either (no change in the results w/wo "Other Equipment". How can I apply the monitored data for the electric equipment? Thank you for your help.
