energyplus reported area is 0
The "Processing Reporting measures" process is failing, alouth the simulation runs fine. For some reason I get the message: Warn: EnergyPlus reported area is 0 (m^2). OpenStudio reported area is 684 (m^2). Warn: Envelope Summary section failed and was skipped because: Wrong arguments for overloaded method 'toNeatString'.
Does anyone know why the reported area becomes 0? Here is the full dump, note the error is listed after the openstudio simulation reults...
Initializing workflow.
Processing OpenStudio Measures.
Translating the OpenStudio Model to EnergyPlus.
Processing EnergyPlus Measures.
Starting Simulation.
EnergyPlus Starting
EnergyPlus, Version 9.4.0-998c4b761e, YMD=2021.06.22 09:29
Adjusting Air System Sizing
Adjusting Standard 62.1 Ventilation Sizing
Initializing Simulation
Reporting Surfaces
Beginning Primary Simulation
Initializing New Environment Parameters
Warming up {1} Starting Simulation at 05/21 for MASBATE ESPINOSA AP ANN CLG .4% CONDNS DB=>MWB Initializing New Environment Parameters Warming up {1} Starting Simulation at 05/21 for MASBATE ESPINOSA AP ANN CLG .4% CONDNS DP=>MDB Initializing New Environment Parameters Warming up {1} Starting Simulation at 05/21 for MASBATE ESPINOSA AP ANN CLG .4% CONDNS ENTH=>MDB Initializing New Environment Parameters Warming up {1} Starting Simulation at 05/21 for MASBATE ESPINOSA AP ANN CLG .4% CONDNS WB=>MDB Initializing New Environment Parameters Warming up {1} Starting Simulation at 05/21 for MASBATE ESPINOSA AP ANN CLG 1% CONDNS DB=>MWB Initializing New Environment Parameters Warming up {1} Starting Simulation at 05/21 for MASBATE ESPINOSA AP ANN CLG 1% CONDNS DP=>MDB Initializing New Environment Parameters Warming up {1} Starting Simulation at 05/21 for MASBATE ESPINOSA AP ANN CLG 1% CONDNS ENTH=>MDB Initializing New Environment Parameters Warming up {1} Starting Simulation at 05/21 for MASBATE ESPINOSA AP ANN CLG 1% CONDNS WB=>MDB Initializing New Environment Parameters Warming up {1} Starting Simulation at 05/21 for MASBATE ESPINOSA AP ANN CLG 2% CONDNS DB=>MWB Initializing New Environment Parameters Warming up {1} Starting Simulation at 05/21 for MASBATE ESPINOSA AP ANN CLG 2% CONDNS DP=>MDB Initializing New Environment Parameters Warming up {1} Starting Simulation at 05/21 for MASBATE ESPINOSA AP ANN CLG 2% CONDNS ENTH=>MDB Initializing New Environment Parameters Warming up {1} Starting Simulation at 05/21 for MASBATE ESPINOSA AP ANN CLG 2% CONDNS WB=>MDB Initializing New Environment Parameters Warming up {1} Starting Simulation at 01/21 for MASBATE ESPINOSA AP ANN HTG 99% CONDNS DB Initializing New Environment Parameters Warming up {1} Starting Simulation at 01/21 for MASBATE ESPINOSA AP ANN HTG 99.6% CONDNS DB Initializing New Environment Parameters Warming up {1} Starting Simulation at 01/21 for MASBATE ESPINOSA AP ANN HTG WIND 99% CONDNS WS=>MCDB Initializing New Environment Parameters Warming up {1} Starting Simulation at 01/21 for MASBATE ESPINOSA AP ANN HTG WIND 99.6% CONDNS WS=>MCDB Initializing New Environment Parameters Warming up {1} Starting Simulation at 01/21 for MASBATE ESPINOSA AP ANN HUM_N 99% CONDNS DP=>MCDB Initializing New Environment Parameters Warming up {1} Starting Simulation at 01/21 for MASBATE ESPINOSA AP ANN HUM_N 99.6% CONDNS DP=>MCDB Initializing New Environment Parameters Warming up {1} Starting Simulation at 04/21 for MASBATE ESPINOSA AP APRIL .4% CONDNS DB=>MCWB Initializing New Environment Parameters Warming up {1} Starting Simulation at 04/21 for MASBATE ESPINOSA AP APRIL .4% CONDNS WB=>MCDB Initializing New Environment Parameters Warming up {1} Starting Simulation at 04/21 for MASBATE ESPINOSA AP APRIL 2% CONDNS DB=>MCWB Initializing New Environment Parameters Warming up {1} Starting Simulation at 04/21 for MASBATE ESPINOSA AP APRIL 2% CONDNS WB=>MCDB Initializing New Environment Parameters Warming up {1} Starting Simulation at 04/21 for MASBATE ESPINOSA AP APRIL 5% CONDNS DB=>MCWB Initializing New Environment Parameters Warming up {1} Starting Simulation at 08/21 for MASBATE ESPINOSA AP AUGUST .4% CONDNS DB=>MCWB Initializing New Environment Parameters Warming up {1} Starting Simulation at 08/21 for MASBATE ESPINOSA AP AUGUST .4% CONDNS WB=>MCDB Initializing New Environment Parameters Warming up {1} Starting Simulation at 08/21 for MASBATE ESPINOSA AP AUGUST 2% CONDNS DB=>MCWB Initializing New Environment Parameters Warming up {1} Starting Simulation at 08/21 for MASBATE ESPINOSA AP AUGUST 2% CONDNS WB=>MCDB Initializing New Environment Parameters Warming up {1} Starting Simulation at 08/21 for MASBATE ESPINOSA AP AUGUST 5% CONDNS DB=>MCWB Initializing New Environment Parameters Warming up {1} Starting Simulation at 12/21 for MASBATE ESPINOSA AP DECEMBER .4% CONDNS DB=>MCWB Initializing New Environment Parameters Warming up {1} Starting Simulation at 12/21 for MASBATE ESPINOSA AP DECEMBER .4% CONDNS WB=>MCDB Initializing New Environment Parameters Warming up {1} Starting Simulation at 12/21 for MASBATE ESPINOSA AP DECEMBER 2% CONDNS DB=>MCWB Initializing New Environment Parameters Warming up {1} Starting Simulation at 12/21 for MASBATE ESPINOSA AP DECEMBER 2% CONDNS WB=>MCDB Initializing New Environment Parameters Warming up {1} Starting Simulation at 12/21 for MASBATE ESPINOSA AP DECEMBER 5% CONDNS DB=>MCWB Initializing New Environment Parameters Warming up {1} Starting Simulation at 02/21 for MASBATE ESPINOSA AP FEBRUARY .4% CONDNS DB=>MCWB Initializing New Environment Parameters Warming up {1} Starting Simulation at 02/21 for MASBATE ESPINOSA AP FEBRUARY .4% CONDNS WB=>MCDB Initializing New Environment Parameters Warming up {1} Starting Simulation at 02/21 for MASBATE ESPINOSA AP FEBRUARY 2% CONDNS DB=>MCWB Initializing New Environment Parameters Warming up {1} Starting Simulation at 02/21 for MASBATE ESPINOSA AP FEBRUARY 2% CONDNS WB=>MCDB Initializing New Environment Parameters Warming up {1} Starting Simulation at 02/21 for MASBATE ESPINOSA AP FEBRUARY 5% CONDNS DB=>MCWB Initializing New Environment Parameters Warming up {1} Starting Simulation at 01/21 for MASBATE ESPINOSA AP JANUARY .4% CONDNS DB=>MCWB Initializing New Environment Parameters Warming up {1} Starting Simulation at 01/21 for MASBATE ESPINOSA AP JANUARY .4% CONDNS WB=>MCDB Initializing New Environment Parameters Warming up {1} Starting Simulation at 01/21 for MASBATE ESPINOSA AP JANUARY 2% CONDNS DB=>MCWB Initializing New Environment Parameters Warming up {1} Starting Simulation at 01/21 for MASBATE ESPINOSA AP JANUARY 2% CONDNS WB=>MCDB Initializing New Environment Parameters Warming up {1} Starting Simulation at 01/21 for MASBATE ESPINOSA AP JANUARY 5% CONDNS DB=>MCWB Initializing New Environment Parameters Warming up {1} Starting Simulation at 07/21 for MASBATE ESPINOSA AP JULY .4% CONDNS DB=>MCWB Initializing New Environment Parameters Warming up {1} Starting Simulation at 07/21 for MASBATE ESPINOSA AP JULY .4% CONDNS WB=>MCDB Initializing New Environment Parameters Warming up {1} Starting Simulation at 07/21 for MASBATE ESPINOSA AP JULY 2% CONDNS DB=>MCWB Initializing New Environment Parameters Warming up {1} Starting Simulation at 07/21 for MASBATE ESPINOSA AP JULY 2% CONDNS WB=>MCDB Initializing New Environment Parameters Warming up {1} Starting Simulation at 07/21 for MASBATE ESPINOSA AP JULY 5% CONDNS DB=>MCWB Initializing New Environment Parameters Warming up {1} Starting Simulation at 06/21 for MASBATE ESPINOSA AP JUNE .4% CONDNS DB=>MCWB Initializing New Environment Parameters Warming up {1} Starting Simulation at 06/21 for MASBATE ESPINOSA AP JUNE .4% CONDNS WB=>MCDB Initializing New Environment Parameters Warming up {1} Starting Simulation at 06/21 for MASBATE ESPINOSA AP JUNE 2% CONDNS DB=>MCWB Initializing New Environment Parameters Warming up {1} Starting Simulation at 06/21 for MASBATE ESPINOSA AP JUNE 2% CONDNS WB=>MCDB Initializing New Environment Parameters Warming up {1} Starting Simulation at 06/21 for MASBATE ESPINOSA AP JUNE 5% CONDNS DB=>MCWB Initializing New Environment Parameters Warming up {1} Starting Simulation at 03/21 for MASBATE ESPINOSA AP MARCH .4% CONDNS DB=>MCWB Initializing New Environment Parameters Warming up {1} Starting Simulation at 03/21 for MASBATE ESPINOSA AP MARCH .4% CONDNS WB=>MCDB Initializing New Environment Parameters Warming up {1} Starting Simulation at 03/21 for MASBATE ESPINOSA AP MARCH 2% CONDNS DB=>MCWB Initializing New Environment Parameters Warming up {1} Starting Simulation at 03/21 for MASBATE ESPINOSA AP MARCH 2% CONDNS WB=>MCDB Initializing New Environment Parameters Warming up {1} Starting Simulation at 03/21 for MASBATE ESPINOSA AP MARCH 5% CONDNS DB=>MCWB Initializing New Environment Parameters Warming up {1} Starting Simulation at 05/21 for MASBATE ESPINOSA AP MAY .4% CONDNS DB=>MCWB Initializing New Environment Parameters Warming up {1} Starting Simulation at 05/21 for MASBATE ESPINOSA AP MAY .4% CONDNS WB=>MCDB Initializing New Environment Parameters Warming up {1} Starting Simulation at 05/21 for MASBATE ESPINOSA AP MAY 2% CONDNS DB=>MCWB Initializing New Environment Parameters Warming up {1} Starting Simulation at 05/21 for MASBATE ESPINOSA AP MAY 2% CONDNS WB=>MCDB Initializing New Environment Parameters Warming up {1} Starting Simulation at 05/21 for MASBATE ESPINOSA AP MAY 5% CONDNS DB=>MCWB Initializing New Environment Parameters Warming up {1} Starting Simulation at 11/21 for MASBATE ESPINOSA AP NOVEMBER .4% CONDNS DB=>MCWB Initializing New Environment Parameters Warming up {1} Starting Simulation at 11/21 for MASBATE ESPINOSA AP NOVEMBER .4% CONDNS WB=>MCDB Initializing New Environment Parameters Warming up {1} Starting Simulation at 11/21 for MASBATE ESPINOSA AP NOVEMBER 2% CONDNS DB=>MCWB Initializing New Environment Parameters Warming up {1} Starting Simulation at 11/21 for MASBATE ESPINOSA AP NOVEMBER 2% CONDNS WB=>MCDB Initializing New Environment Parameters Warming up {1} Starting Simulation at 11/21 for MASBATE ESPINOSA AP NOVEMBER 5% CONDNS DB=>MCWB Initializing New Environment Parameters Warming up {1} Starting Simulation at 10/21 for MASBATE ESPINOSA AP OCTOBER .4% CONDNS DB=>MCWB Initializing New Environment Parameters Warming up {1} Starting Simulation at 10/21 for MASBATE ESPINOSA AP OCTOBER .4% CONDNS WB=>MCDB Initializing New Environment Parameters Warming up {1} Starting Simulation at 10/21 for MASBATE ESPINOSA AP OCTOBER 2% CONDNS DB=>MCWB Initializing New Environment Parameters Warming up {1} Starting Simulation at 10/21 for MASBATE ESPINOSA AP OCTOBER 2% CONDNS WB=>MCDB Initializing New Environment Parameters Warming up {1} Starting Simulation at 10/21 for MASBATE ESPINOSA AP OCTOBER 5% CONDNS DB=>MCWB Initializing New Environment Parameters Warming up {1} Starting Simulation at 09/21 for MASBATE ESPINOSA AP SEPTEMBER .4% CONDNS DB=>MCWB Initializing New Environment Parameters Warming up {1} Starting Simulation at 09/21 for MASBATE ESPINOSA AP SEPTEMBER .4% CONDNS WB=>MCDB Initializing New Environment Parameters Warming up {1} Starting Simulation at 09/21 for MASBATE ESPINOSA AP SEPTEMBER 2% CONDNS DB=>MCWB Initializing New Environment Parameters Warming up {1} Starting Simulation at 09/21 for MASBATE ESPINOSA AP SEPTEMBER 2% CONDNS WB=>MCDB Initializing New Environment Parameters Warming up {1} Starting Simulation at 09/21 for MASBATE ESPINOSA AP SEPTEMBER 5% CONDNS DB=>MCWB Initializing New Environment Parameters Warming up {1} Starting Simulation at 01/01/2010 for RUN PERIOD 1 Updating Shadowing Calculations, Start Date=01/21/2010 Continuing Simulation at 01/21/2010 for RUN PERIOD 1 Updating Shadowing Calculations, Start Date=02/10/2010 Continuing Simulation at 02/10/2010 for RUN PERIOD 1 Updating Shadowing Calculations, Start Date=03/02/2010 Continuing Simulation at 03/02/2010 for RUN PERIOD 1 Updating Shadowing Calculations, Start Date=03/22/2010 Continuing Simulation at 03/22/2010 for RUN PERIOD 1 Updating Shadowing Calculations, Start Date=04/11/2010 Continuing Simulation at 04/11/2010 for RUN PERIOD 1 Updating Shadowing Calculations, Start Date=05/01/2010 Continuing Simulation at 05/01/2010 for RUN PERIOD 1 Updating Shadowing Calculations, Start Date=05/21/2010 Continuing Simulation at 05/21/2010 for RUN PERIOD 1 Updating Shadowing Calculations, Start Date=06/10/2010 Continuing Simulation at 06/10/2010 for RUN PERIOD 1 Updating Shadowing Calculations, Start Date=06/30/2010 Continuing Simulation at 06/30/2010 for RUN PERIOD 1 Updating Shadowing Calculations, Start Date=07/20/2010 Continuing Simulation at 07/20/2010 for RUN PERIOD 1 Updating Shadowing Calculations, Start Date=08/09/2010 Continuing Simulation at 08/09/2010 for RUN PERIOD 1 Updating Shadowing Calculations, Start Date=08/29/2010 Continuing Simulation at 08/29/2010 for RUN PERIOD 1 Updating Shadowing Calculations, Start Date=09/18/2010 Continuing Simulation at 09/18/2010 for RUN PERIOD 1 Updating Shadowing Calculations, Start Date=10/08/2010 Continuing Simulation at 10/08/2010 for RUN PERIOD 1 Updating Shadowing Calculations, Start Date=10/28/2010 Continuing Simulation at 10/28/2010 for RUN PERIOD 1 Updating Shadowing Calculations, Start Date=11/17/2010 Continuing Simulation at 11/17/2010 for RUN PERIOD 1 Updating Shadowing Calculations, Start Date=12/07/2010 Continuing Simulation at 12/07/2010 for RUN PERIOD 1 Updating Shadowing Calculations, Start Date=12/27/2010 Continuing Simulation at 12/27/2010 for RUN PERIOD 1
Writing tabular output file results using HTML format.
Computing Life Cycle Costs and Reporting
Writing final SQL reports
EnergyPlus Run Time=00hr 00min 3.21sec
EnergyPlus Completed Successfully.
Processing Reporting Measures.
Applying OpenStudioResults
Result: Success
Initial Condition: Gathering data from EnergyPlus SQL file and OSM model. Will report in IP Units
Final Condition: Generated report with 20 sections to ./report.html.
Possible C/C++ prototypes are:
std::string toNeatString(double value, unsigned int numFractionalDigits, bool applyCommas)
std::string toNeatString(double value, unsigned int numFractionalDigits)
std::string toNeatString(double value)
. Detail on error follows: C:/Users/Euroland/AppData/Local/Temp/osmodel-1624262702
-1/resources/measures/OpenStudioResults/measure.rb:289:in `eval'
-1/resources/measures/OpenStudioResults/resources/os_lib_reporting.rb:1752:in `block in envelope_section_section'
C:/Users/Euroland/AppData/Local/Temp/osmodel-1624262702-1/resources/measures/OpenStudioResults/resources/os_lib_reporting.rb:1736:in `each'
C:/Users/Euroland/AppData/Local/Temp/osmodel-1624262702-1/resources/measures/OpenStudioResults/resources/os_lib_reporting.rb:1736:in `envelope_section_section'
(eval):1:in `block in run'
C:/Users/Euroland/AppData/Local/Temp/osmodel-1624262702-1/resources/measures/OpenStudioResults/measure.rb:289:in `eval'
C:/Users/Euroland/AppData/Local/Temp/osmodel-1624262702-1/resources/measures/OpenStudioResults/measure.rb:289:in `block in run'
C:/Users/Euroland/AppData/Local/Temp/osmodel-1624262702-1/resources/measures/OpenStudioResults/measure.rb:286:in `each'
C:/Users/Euroland/AppData/Local/Temp/osmodel-1624262702-1/resources/measures/OpenStudioResults/measure.rb:286:in run' :/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb:519:inapply_measure' :/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb:114:in `block in
apply_measures' :/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb:67:in each_index' :/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb:67:inapply_measures' :/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/jobs/run_reporting_measures.rb:105:in perform' :/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/run.rb:292:instep' :/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/run.rb:234:in run' :/openstudio_cli.rb:971:inexecute' :/openstudio_cli.rb:761:in execute' :/openstudio_cli.rb:1755:in<main>'
eval:175:in `eval'
eval:175:in `require_embedded_absolute'
eval:160:in `block in require_embedded'
eval:154:in `each'
eval:154:in `require_embedded'
eval:113:in `require'
eval:3:in `<main>'
Warn: Interior Lighting Summary section failed and was skipped because: Optional not initialized. Detail on error follows: C:/Users/Euroland/AppData/Local/Temp/osmodel-1624262702-1/resources/measures/OpenStudioResults/measure.rb:289:in eval' C:/Users/Euroland/AppData/Local/Temp/osmodel-1624262702-1/resources/measures/OpenStudioResults/resources/os_lib_reporting.rb:3344:inblock in interior_lighting_section' C:/Users/Euroland/AppData/Local/Temp/osmodel-1624262702-1/resources/measures/OpenStudioResults/resources/os_lib_reporting.rb:3343:in each' C:/Users/Euroland/AppData/Local/Temp/osmodel-1624262702-1/resources/measures/OpenStudioResults/resources/os_lib_reporting.rb:3343:ininterior_lighting_section' (eval):1:in block in run' C:/Users/Euroland/AppData/Local/Temp/osmodel-1624262702-1/resources/measures/OpenStudioResults/measure.rb:289:ineval' C:/Users/Euroland/AppData/Local/Temp/osmodel-1624262702-1/resources/measures/OpenStudioResults/measure.rb:289:in block in run' C:/Users/Euroland/AppData/Local/Temp/osmodel-1624262702-1/resources/measures/OpenStudioResults/measure.rb:286:ineach' C:/Users/Euroland/AppData/Local/Temp/osmodel-1624262702-1/resources/measures/OpenStudioResults/measure.rb:286:in run' :/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb:519:inapply_measure' :/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb:114:in block in apply_measures' :/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb:67:ineach_index' :/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb:67:in apply_measures' :/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/jobs/run_reporting_measures.rb:105:inperform' :/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/run.rb:292:in step' :/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/run.rb:234:inrun' :/openstudio_cli.rb:971:in execute' :/openstudio_cli.rb:761:inexecute' :/openstudio_cli.rb:1755:in `<main>'
eval:175:in `eval'
eval:154:in `each'
eval:3:in `<main>'
Gathering Reports.
Failed.
EnergyPlus Starting
Reporting Surfaces
Result: Success
eval:175:in `eval'
eval:154:in `each'
eval:3:in `<main>'
eval:175:in `eval'
eval:154:in `each'
eval:3:in `<main>'
Gathering Reports.
Failed.
EnergyPlus Starting
Reporting Surfaces
Result: Success
eval:175:in `eval'
eval:154:in `each'
eval:3:in `<main>'
eval:175:in `eval'
eval:154:in `each'
eval:3:in `<main>'
Gathering Reports.
Failed.
