ALL geometry disappears in OpenStudio
I am currently using Sketchup Make 2016, Openstudio 1.13. I created the spaces using the extrude tool, named the spaces, saved and closed the model. Upon reopening, all the surfaces have disappeared. I do get errors such as:
Error: Surface 202 This planar surface shares the same SketchUp face as Surface 2242. This error cannot be automatically fixed. The surface will not be drawn.
I have tried solving using this method shown in this link: https://unmethours.com/question/1646/geometry-diagnostic-steps-in-openstudio-sketchup-mode/. However, the errors aren't the same, and running through the steps from that link doesn't do anything. Counterclockwise: Fix unintended reversed face Counterclockwise: Fix unintended reversed face Counterclockwise: Fix unintended reversed face Counterclockwise: Fix unintended reversed face Surface.face_polygon: entity not valid Surface.face_polygon: entity not valid
I have also tried using the diagnostic script, which found no errors. The only evidence that the spaces do exist is if I open the .osm file and see the spaces. And the OpenStudio Inspector also shows the spaces. I have
I have also tried using the diagnostic script, which found no errors. The only evidence that the spaces do exist is if I open the .osm file and see the spaces. And the OpenStudio Inspector also shows the spaces. I havespaces.
