Hello i am using OS 3.1.0 and when i try to run te simulation with the measure of radiance the simulation do not run, with the next mensage:
Result: Fail
Error: No such file or directory @ rb_sysopen - C:/Users/Byron/AppData/Local/Temp/osmodel-1623473679-0/resources/run/000_RadianceMeasure/radiance/options/treg.opt
eval:425:in initialize'
eval:425:inopen'
eval:425:in open'
C:/Users/Byron/AppData/Local/Temp/osmodel-1623473679-0/resources/measures/RadianceMeasure/measure.rb:736:inrun'
:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb:515:in apply_measure'
:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb:114:inblock in apply_measures'
:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb:67:in each_index'
:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb:67:inapply_measures'
:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/jobs/run_os_measures.rb:70:in perform'
:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/run.rb:292:instep'
:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/run.rb:234:in run'
:/openstudio_cli.rb:971:inexecute'
:/openstudio_cli.rb:761:in execute'
:/openstudio_cli.rb:1755:in<main>'
eval:175:in eval'
eval:175:inrequire_embedded_absolute'
eval:160:in block in require_embedded'
eval:154:ineach'
eval:154:in require_embedded'
eval:113:inrequire'
eval:3:in `<main>'
Info: Begin Encoding.default_external = UTF-8
Info: Begin Encoding.default_internal =
Info: Radiance multiprocessing features are not supported on Windows.
Info: Using 1 core(s) for Radiance jobs
Info: Found Radiance at: C:\openstudioapplication-1.1.0\Radiance
Info: Found Perl at:
Info: Found EnergyPlus at: C:\openstudioapplication-1.1.0\EnergyPlus\energyplus.exe
Info: Radiance version: NREL 5.0.a.12 (by googs 2016.10.04) based on RADIANCE 5.0 Official Release by G. Ward
Info: Radiance binary dir: C:\openstudioapplication-1.1.0\Radiance\bin
Info: Radiance library dir: C:\openstudioapplication-1.1.0\Radiance\lib
Info: Translating OpenStudio 2.x model to Radiance format...
Info: OpenStudio CLI version: 3.1.0+82d3ea2978
Failed.
Can someone please help me. Thank you so much
