Hi everyone,
I added a variable-speed pump in the condenser loop and changed the "Chiller Flow Mode" to "LeavingSetpointModulated".
However, the water flow rate of the variable-speed pump is constant throughout the year, and of course, the power consumption is almost the same as a constant speed pump.
I found the same situation happened in this post, and it seems unsolved.
Therefore, I was wondering if there is an alternative approach to simulate a variable-speed pump in the condenser loop?
Thank you.
