C:\fakepath\2 floor structures.pngHello,
In all radiant system example files, the radiant system is assigned to a whole surface. What if I want to assign the radiant system to part of the floor area?
Is it possible to build a floor surface in EnergyPlus that has 2 different structures? For example, part of the floor defined as a 4" concrete and the other part of the floor area to be composed of different materials that are defined in the "Construction:Internal Source"?
Thanks, Amir
