Hello everybody, I would like ta add a heat pump on hvac exhaust air to heat hot water or water heating loop. I didn't find a way of doing so. The zonal air to water heat pump could be a solution, but the air flow rate seems hard linked to the HP operation, while I need a scheduled air flow rate. Any help would be much appreciated. Thanx for all the other useful replies too. Michael
