Hi all,
I'm trying to model DHW pipe insulation in the IECC 2006 PNNL prototype model SF+ elecres + crawlspace in version 9.4. Using the IDF editor to model. How to model pipe insulation?
I tried these steps:
- Created a new object called "Pipe Insulation" in Class: Material and used it as an additional layer in object :Pipe, under Class: Construction.
- Created new objects in Class: Pipe:Indoor for "DHW Supply Outlet Pipe_unit1" & "DHW Demand Inlet Pipe_unit1" assuming the pipe diameter as .75 inch and length as 6 feet. Deleted the same objects from Pipe:Adiabatic.
- Edited Class: Branch. Changed component object type 1 from Pipe:Adiabatic to pipe:Indoor for Objects "DHW Supply
Outlet Branch_unit1" & "DHW Demand Inlet Branch_unit1" , as I am trying to give insulated pipe for DHW outlet.
Is this the correct way to vary the pipe insulation for DHW? Why am I seeing variation in heating and cooling energy consumption? I would appreciate your inputs. Thanks in advance
