Annual Summary not loading
I am having this same issue as:
https://unmethours.com/question/50935/annual-overview-openstudio-31-and-e-94/
But I can't add pictures to that thread. I'm including the rest of the error message and the version i am using.
Everything else looks fine.
Initial Condition: Gathering data from EnergyPlus SQL file and OSM model. Will report in IP Units
Final Condition: Generated report with 20 sections to ./report.html.
Warn: Annual Overview section failed and was skipped because: Optional not initialized. Detail on error follows.
Warn: C:/Users/Steve/AppData/Local/Temp/osmodel-1614617690-0/resources/measures/OpenStudioResults 1/measure.rb:278:in eval'
C:/Users/Steve/AppData/Local/Temp/osmodel-1614617690-0/resources/measures/OpenStudioResults 1/resources/os_lib_reporting.rb:540:inblock in output_data_end_use_table'
C:/Users/Steve/AppData/Local/Temp/osmodel-1614617690-0/resources/measures/OpenStudioResults 1/resources/os_lib_reporting.rb:530:in each'
C:/Users/Steve/AppData/Local/Temp/osmodel-1614617690-0/resources/measures/OpenStudioResults 1/resources/os_lib_reporting.rb:530:inoutput_data_end_use_table'
C:/Users/Steve/AppData/Local/Temp/osmodel-1614617690-0/resources/measures/OpenStudioResults 1/resources/os_lib_reporting.rb:258:in annual_overview_section'
(eval):1:inblock in run'
C:/Users/Steve/AppData/Local/Temp/osmodel-1614617690-0/resources/measures/OpenStudioResults 1/measure.rb:278:inblock in run'
C:/Users/Steve/AppData/Local/Temp/osmodel-1614617690-0/resources/measures/OpenStudioResults 1/measure.rb:274:in each'
C:/Users/Steve/AppData/Local/Temp/osmodel-1614617690-0/resources/measures/OpenStudioResults 1/measure.rb:274:inrun'
:/ruby/2.5.0/gems/openstudio-workflow-2.1.1/lib/openstudio/workflow/util/measure.rb:519:in apply_measure'
:/ruby/2.5.0/gems/openstudio-workflow-2.1.1/lib/openstudio/workflow/util/measure.rb:114:inblock in apply_measures'
:/ruby/2.5.0/gems/openstudio-workflow-2.1.1/lib/openstudio/workflow/util/measure.rb:67:in each_index'
:/ruby/2.5.0/gems/openstudio-workflow-2.1.1/lib/openstudio/workflow/util/measure.rb:67:inapply_measures'
:/ruby/2.5.0/gems/openstudio-workflow-2.1.1/lib/openstudio/workflow/jobs/run_reporting_measures.rb:119:in perform'
:/ruby/2.5.0/gems/openstudio-workflow-2.1.1/lib/openstudio/workflow/run.rb:292:instep'
:/ruby/2.5.0/gems/openstudio-workflow-2.1.1/lib/openstudio/workflow/run.rb:234:in run'
:/openstudio_cli.rb:971:inexecute'
:/openstudio_cli.rb:761:in execute'
:/openstudio_cli.rb:1755:in<main>'
eval:175:in eval'
eval:175:inrequire_embedded_absolute'
eval:160:in block in require_embedded'
eval:154:ineach'
eval:154:in require_embedded'
eval:113:inrequire'
eval:3:in `<main>'
