floor cooling and floor heating with borehole
I am a master student working on my thesis. I am modelling a building in OS 2.7.0
You can find my OS model and a picture of the system at following link(https://we.tl/t-sEF0x4SjAc). I have implemented a vertical borehole with a heat pump (heating) and heat exchanger (cooling).
I am working trying to implement my plant loop but I am still getting warning errors.
*** * Warning * Plant loop exceeding upper temperature limit, PlantLoop="GEOTHERMISCHE WARMTEWISSELAAR KOELING-DEEL 2" *** * ~~~ * This error occurred 61957 total times; *** * ~~~ * during Warmup 22873 times; *** * ~~~ * during Sizing 0 times. *** * ~~~ * Max=46.731946 A water temperature of 46°C for floorcooling is to much it should be around 20°C. Are there suggestions to improve my plant model? To solve this problem? ( I cannot place pictures in my question level to low)
*************  ** Warning * ** Plant loop exceeding upper temperature limit, PlantLoop="GEOTHERMISCHE WARMTEWISSELAAR KOELING-DEEL 2"
   *** *   ~~~   * *************  **   ~~~   **   This error occurred 61957 total times;
   *** *   ~~~   * *************  **   ~~~   **   during Warmup 22873 times;
   *** *   ~~~   * *************  **   ~~~   **   during Sizing 0 times.
   *** *   ~~~   * *************  **   ~~~   **   Max=46.731946
*************  ** Warning ** Plant loop exceeding upper temperature limit, PlantLoop="GEOTHERMISCHE WARMTEWISSELAAR KOELING-DEEL 2"
