Hi all,
I am using ResStock v2.2.4, EnergyPlus v9.2, and OS v2.9.0.
I am trying to represent the Daikin 3MXL 3-port 2-ton rated heat pump in Maine.
On Daikin's submittal sheet, the rated cooling capacity equals the rated heating capacity:
I specified in hvac_sizing.rb that the heating capacity offset should be zero:
However, in the ResStock output, the heating capacity clearly does not equal the cooling capacity:
Any ideas why this is happening?
In options_lookup tsv, I have created a new row entry for the 3MXL and designated the following fields:
- heat_pump_capacity=2
- heating_capacity_offset=0
- min_cooling_capacity=0.44, max_cooling_capacity=1.25
- min_heating_capacity=0.33, max_heating_capacity=1.71
- supplemental_capacity=autosize
Either way, I am getting really large heating unmet hours for this equipment because some houses simulated probably require greater total capacity than 2-tons, so it is possible I should just scrap this equipment entirely and rely on ResStock's default equipment.
