Hi all, there is a temperature node for inlet and outlet air temperature in cooling coil part in energy plus. in the out put file i got result for temperature node. based on the result the inlet and outlet air temperature of the cooling coil is constant in winter. Also in heat pump cooling coil in large office building the supply air is from data center and the inlet air temperature in cooling coil i constant about 27c. would you please guide me n this issue. i am not sure my result is correct or not
