Control ERV flow rates using DesignSpecification?
Hi all,
I am wondering if I can control a simple ZoneHVAC:EnergyRecoveryVentilator using an DesignSpecification:OutdoorAir ?
I was trying to apply a simple residential PTHP + ERV to my thermal zones in OpenStudio: image description
I first set up the PTHP to work properly and used a space-type level OutdoorAir flow-rate to set the OA flows through those units globally: image description
That worked (I think) and I seemed to be getting good results. I then added the ERV and noticed that now the OA flows were changed substantially. I notice that the ERV unit has its own flow-rate inputs at the unit-level? image description
I there a way to tell these ERVs to ignore these unit-level flow-rates and instead refer back to the DesignSpecification:OutdoorAir flow-rates that I already set for the space-types?
I very much appreciate any advice or thoughts anyone might have. Thanks so much,
-Ed
Hi all,
-Ed
Hi all,
-Ed
