Hi,
I am trying to get familiar with Openstudio. My supervisor sent a geometry to me( it can be seen only in 3d view , can not be edited) and I tried to run this project for energy plus, (energy modelling ) with some deafult values and ideal air loads but I did not get a succesfull simulation results. It always failed. I dont know it has an easy solution or not because ,as i said before, I dont have any experience in this program before. Thanks in advance. This is the full text of the error:
[23:28:51.948620 ERROR] undefined method getString' for nil:NilClass
C:/Users/taskiran/AppData/Local/Temp/osmodel-1609194148-0/resources/measures/AddOutputDiagnostics/measure.rb:132:inrun'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:512:in apply_measure'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:109:inblock in apply_measures'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:67:in each_index'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:67:inapply_measures'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/jobs/run_ep_measures.rb:59:in perform'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:292:instep'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:234:in run'
:/openstudio_cli.rb:973:inexecute'
:/openstudio_cli.rb:763:in execute'
:/openstudio_cli.rb:1757:in<main>'
eval:149:in eval'
eval:149:inrequire_embedded_absolute'
eval:123:in block in require'
eval:117:ineach'
eval:117:in require'
eval:3:in<main>'
[23:28:51.962613 ERROR] :/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb failed with message Runner error :/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb failed with undefined method getString' for nil:NilClass, C:/Users/taskiran/AppData/Local/Temp/osmodel-1609194148-0/resources/measures/AddOutputDiagnostics/measure.rb:132:inrun'
eval:149:in eval'
eval:117:ineach'
eval:3:in<main>' in :/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:538:in rescue in apply_measure'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:498:inapply_measure'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:109:in block in apply_measures'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:67:ineach_index'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:67:in apply_measures'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/jobs/run_ep_measures.rb:59:inperform'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:292:in step'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:234:inrun'
:/openstudio_cli.rb:973:in execute'
:/openstudio_cli.rb:763:inexecute'
:/openstudio_cli.rb:1757:in <main>'
eval:149:ineval'
eval:149:in require_embedded_absolute'
eval:123:inblock in require'
eval:117:in each'
eval:117:inrequire'
eval:3:in <main>'
[23:28:51.964506 ERROR] Found error in state 'ep_measures' with message [":/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb failed with message Runner error :/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb failed with undefined methodgetString' for nil:NilClass, C:/Users/taskiran/AppData/Local/Temp/osmodel-1609194148-0/resources/measures/AddOutputDiagnostics/measure.rb:132:in run'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:512:inapply_measure'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:109:in block in apply_measures'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:67:ineach_index'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:67:in apply_measures'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/jobs/run_ep_measures.rb:59:inperform'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:292:in step'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:234:inrun'\n:/openstudio_cli.rb:973:in execute'\n:/openstudio_cli.rb:763:inexecute'\n:/openstudio_cli.rb:1757:in <main>'\neval:149:ineval'\neval:149:in require_embedded_absolute'\neval:123:inblock in require'\neval:117:in each'\neval:117:inrequire'\neval:3:in <main>' in :/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:538:inrescue in apply_measure'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:498:in apply_measure'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:109:inblock in apply_measures'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:67:in each_index'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:67:inapply_measures'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/jobs/run_ep_measures.rb:59:in perform'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:292:instep'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:234:in run'\n:/openstudio_cli.rb:973:inexecute'\n:/openstudio_cli.rb:763:in execute'\n:/openstudio_cli.rb:1757:in<main>'\neval:149:in eval'\neval:149:inrequire_embedded_absolute'\neval:123:in block in require'\neval:117:ineach'\neval:117:in require'\neval:3:in<main>'::/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:647:in rescue in apply_measure'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:305:inapply_measure'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:109:in block in apply_measures'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:67:ineach_index'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/measure.rb:67:in apply_measures'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/jobs/run_ep_measures.rb:59:inperform'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:292:in step'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:234:inrun'\n:/openstudio_cli.rb:973:in execute'\n:/openstudio_cli.rb:763:inexecute'\n:/openstudio_cli.rb:1757:in <main>'\neval:149:ineval'\neval:149:in require_embedded_absolute'\neval:123:inblock in require'\neval:117:in each'\neval:117:inrequire'\neval:3:in `<main>'"]}
