My model can run completely, but when I see svg file. It's not a good connection.Like this:
some of my object have listed.
AirTerminal:SingleDuct:VAV:Reheat,
VAV_A1, !- Name
All On, !- Availability Schedule Name
VAV_A1 Box Damper Node, !- Damper Air Outlet Node Name
VAV_A1 Box Inlet Node, !- Air Inlet Node Name
autosize, !- Maximum Air Flow Rate {m3/s}
Constant, !- Zone Minimum Air Flow Input Method
autosize, !- Constant Minimum Air Flow Fraction
, !- Fixed Minimum Air Flow Rate {m3/s}
, !- Minimum Air Flow Fraction Schedule Name
Coil:Heating:Water, !- Reheat Coil Object Type
VAV_A1 Box Reheat Coil, !- Reheat Coil Name
autosize, !- Maximum Hot Water or Steam Flow Rate {m3/s}
0, !- Minimum Hot Water or Steam Flow Rate {m3/s}
VAV_A1 Box outlet node, !- Air Outlet Node Name
0.001, !- Convergence Tolerance
Reverse, !- Damper Heating Action
autosize, !- Maximum Flow per Zone Floor Area During Reheat {m3/s-m2}
autosize; !- Maximum Flow Fraction During Reheat
ZoneHVAC:AirDistributionUnit,
VAV_A1 BOX, !- Name
VAV_A1 Box outlet node, !- Air Distribution Unit Outlet Node Name
AirTerminal:SingleDuct:VAV:Reheat, !- Air Terminal Object Type
VAV_A1; !- Air Terminal Name
ZoneHVAC:EquipmentList,
F1_Northroom Equipment, !- Name
SequentialLoad, !- Load Distribution Scheme
ZoneHVAC:AirDistributionUnit, !- Zone Equipment 1 Object Type
VAV_C1 BOX, !- Zone Equipment 1 Name
1, !- Zone Equipment 1 Cooling Sequence
1, !- Zone Equipment 1 Heating or No-Load Sequence
, !- Zone Equipment 1 Sequential Cooling Fraction Schedule Name
, !- Zone Equipment 1 Sequential Heating Fraction Schedule Name
ZoneHVAC:AirDistributionUnit, !- Zone Equipment 2 Object Type
VAV_C2 BOX, !- Zone Equipment 2 Name
2, !- Zone Equipment 2 Cooling Sequence
2; !- Zone Equipment 2 Heating or No-Load Sequence
ZoneHVAC:EquipmentConnections,
FL1_Northroom, !- Zone Name
F1_Northroom Equipment, !- Zone Conditioning Equipment List Name
F1_Northroom VAV List, !- Zone Air Inlet Node or NodeList Name
, !- Zone Air Exhaust Node or NodeList Name
Zone F1_N Air node, !- Zone Air Node Name
Zone F1_N return air node; !- Zone Return Air Node or NodeList Name
Any help would be appreciated
