Hi! Me and my team are running some tests with a model and the measure Wind and Stack are failing. With the simulation alone it works fine but give me a lot of warnings. This is with the measure:
Program Version,EnergyPlus, Version 9.2.0-921312fa1d, YMD=2020.11.23 15:24, * Severe * <root>[ZoneVentilation:WindandStackOpenArea][Sub Surface 52_WindandStackOpenArea][height_difference] - Value type "string" for input "Default 0.5 Open Fractional Schedule" not permitted by 'type' constraint. * Severe * <root>[ZoneVentilation:WindandStackOpenArea][Sub Surface 52_WindandStackOpenArea][maximum_indoor_temperature] - Value type "string" for input "Autocalculate" not permitted by 'type' constraint. * Severe * <root>[ZoneVentilation:WindandStackOpenArea][Sub Surface 52_WindandStackOpenArea][minimum_indoor_temperature] - "180.000000" - Expected number less than or equal to 100.000000 * Severe * <root>[ZoneVentilation:WindandStackOpenArea][Sub Surface 52_WindandStackOpenArea][opening_effectiveness] - Value type "string" for input "18 e 19 - Bloco Menor - Esquerda - Pav Superior" not permitted by 'type' constraint. * Severe * <root>[ZoneVentilation:WindandStackOpenArea][Sub Surface 52_WindandStackOpenArea][opening_effectiveness] - Failed to validate against child schema #0. * Severe * <root>[ZoneVentilation:WindandStackOpenArea][Sub Surface 52_WindandStackOpenArea][opening_effectiveness] - "18 e 19 - Bloco Menor - Esquerda - Pav Superior" - Failed to match against any enum values. * Severe * <root>[ZoneVentilation:WindandStackOpenArea][Sub Surface 52_WindandStackOpenArea][opening_effectiveness] - Failed to validate against child schema #1. * Severe * <root>[ZoneVentilation:WindandStackOpenArea][Sub Surface 52_WindandStackOpenArea][opening_effectiveness] - Failed to validate against any child schemas allowed by anyOf constraint. * Fatal * Errors occurred on processing input file. Preceding condition(s) cause termination. ...Summary of Errors that led to program termination: ..... Reference severe error count=8 ..... Last severe error=<root>[ZoneVentilation:WindandStackOpenArea][Sub Surface 52_WindandStackOpenArea][opening_effectiveness] - Failed to validate against any child schemas allowed by anyOf constraint. *** Warning: Node connection errors not checked - most system input has not been read (see previous warning). *** Fatal error -- final processing. Program exited before simulations began. See previous error messages. *** EnergyPlus Warmup Error Summary. During Warmup: 0 Warning; 0 Severe Errors. *** EnergyPlus Sizing Error Summary. During Sizing: 0 Warning; 0 Severe Errors. *** EnergyPlus Terminated--Fatal Error Detected. 0 Warning; 8 Severe Errors; Elapsed Time=00hr 00min 0.90sec
