I am currently running the python plugin examples of the energyplus 9.4 and using the command line script as below. I am running the ThermochromicWindow example
energyplus -w C:/EnergyPlusV9-4-0/WeatherData/USA_IL_Chicago-OHare.Intl.AP.725300_TMY3.epw -d C:/Users/Sajit/Desktop/Sajiths/Research/Python/Run_outputs -r C:/Users/Sajit/Desktop/Sajiths/Research/Python/EMS_via_EP/Examples/Window_control/PythonPluginThermochromicWindow.idf
I tried to change the python script and run another case to make sure there is the impact of the python plugin on the energyplus. But I do get the same results. (For instance, I am outputting the window exterior and interior surface temperature). My doubt is that although energyplus runs the plugin is not contributing.
Appreciate any feedback on this matter. Kind regards,
