There is not reheating in the Air terminal with reheat
I modeled a CAV with terminal reheat, but here is no reheating effect in the terminal. The air temperatures before and after the air terminal are the same. The zone air temperature is quite low. I also tried VAV with terminal reheat, no reheating effect neither.
Has anyone experienced this problem? Thank you.
Has anyone experienced this problem? Thank you.you. image description
Has anyone experienced this problem? Thank you. image description
