I am using version 3.0.1 of OpenStudio, and the application tab is immobile and cannot be made bigger or smaller, when not in full-screen mode, and is restricting access to the run and results tab.
When the application is full-screen, a grey bar appears across the bottom of the screen, which is restricting access to the run and results tabs.
