Hi, I have two cooling coil in my plant Loop and I will like to control them via mass flow rate in their different separate branch.
Methods that I have tried:
As I am unable to put in the pump in the individual branch of before the cooling coil, I am unable to set up the EMS control for the pump flow rate
I have tried controlling using EMS Actuator "System Node Setpoint", control type "Mass Flow Rate Setpoint" on the specific node but I cannot control them even though I have put a setpoint manager schedule (mass flow rate) at that node
May I seek for advice if there is any other way to control the water mass flow rate of the different cooling coil?
Below is the picture of my Plant Loop I am referring to C:\fakepath\Cooling Coil.PNG
Below is the link to my idf file: https://drive.google.com/file/d/1Xwu9BWx3_TpltkZjk9p5EdWSIxXpabh4/view?usp=sharing
