To run energyplus I am using the code given in this link, https://bigladdersoftware.com/epx/docs/9-3/input-output-reference/group-python-plugins.html#python-plugin
import sys
sys.path.insert(0,'C:\EnergyPlusV9-4-0') #sys.path.insert(0, '/path/to/EnergyPlusInstallRoot')
from pyenergyplus.plugin import EnergyPlusPlugin
class DummyPlugin(EnergyPlusPlugin):
def on_end_of_zone_timestep_before_zone_reporting(self):
return 0
The code runs without an issue. But my concern has been how touse this effectively to run a EMS in an IDF. It would be great to have an example which has successfully run an EP idf using the above technique.
Regards,
