Greeting to All,
My file keep crashing when I open it directly from the Openstudio program or when I go thru Sketchup 2017. I read some similar questions similar to this one, and tried searching for loose geometry. I am not the expert, so, I really don't the coding very well. Also, I tried surface matching and everything is matches. In addition, after surface matching and successfully got into Openstudio, when reviewing the model from the geometry tab, if I can get there, I see a diagonal line on the face of the model, what up with that? Changes in Sketchup 2017 don't always carry thru to Openstudio when I launch the program from within Sketchup 2017
My second question - Will the current version of Openstudio, Ver 3.0.1 work with Sketchup 2017. What is your straight forward opinion on using Sketchup 2017 with Openstudio.
My model with not attach to this post.
Thanks, James.
