OS reset surface vertices when resetting XYZ origins of the space
hi i'm trying to reset the XYZ origins of a space to 0,0,0, but find that the vertices of the surfaces associated with the space stays the same and the geometry all get messed up. Is there a way to reset the surfaces along with the XYZ origin changes of the space?
I used the space.resetXOrigin() in the measure.
