I installed PAT 3.0.1 and remove the firewall, however, the local server is always offline. These are Developer Tools errors:
undefined/status.json Failed to load resource: net::ERR_FILE_NOT_FOUND
vendor-ad64e72158.js:24014 PING: Server is not started (anonymous) @ vendor-ad64e72158.js:24014 app-77544dda7e.js:8723 child exited due to receipt of signal null (exit code 1) vendor-ad64e72158.js:24014 Server failed to start (anonymous) @ vendor-ad64e72158.js:24014 vendor-ad64e72158.js:24014 SERVER ERROR (anonymous) @ vendor-ad64e72158.js:24014 app-77544dda7e.js:8706 exec error: Error: Command failed: "D:\ParametricAnalysisTool\pat\ruby\bin\ruby.exe" "D:\ParametricAnalysisTool\pat\OpenStudio-server\bin\openstudio_meta" start_local --worker-number=11 --energyplus-exe-path="D:\ParametricAnalysisTool\pat\EnergyPlus\energyplus.exe" --openstudio-exe-path="D:\ParametricAnalysisTool\pat\OpenStudio\bin\openstudio.exe" --ruby-lib-path="D:\ParametricAnalysisTool\pat\OpenStudio\Ruby" --mongo-dir="D:\ParametricAnalysisTool\pat\mongo\bin" --debug "D:\SRTP\Roof\Qiangongyuan Roof R-value"
at ChildProcess.exithandler (child_process.js:282)
at emitTwo (events.js:130)
at ChildProcess.emit (events.js:213)
at maybeClose (internal/child_process.js:921)
at Process.ChildProcess._handle.onexit (internal/child_process.js:211)
app-77544dda7e.js:8715 child closed due to receipt of signal null (exit code 1) vendor-ad64e72158.js:24014 ERROR in start local server: undefined (anonymous) @ vendor-ad64e72158.js:24014 vendor-ad64e72158.js:24014 START SERVER...SERVER TYPE: local vendor-ad64e72158.js:24014 SERVER STATUS: stopped vendor-ad64e72158.js:24014 stop server command: "D:\ParametricAnalysisTool\pat\ruby\bin\ruby.exe" "D:\ParametricAnalysisTool\pat\OpenStudio-server\bin\openstudio_meta" stop_local "D:\SRTP\Roof\Qiangongyuan Roof R-value" vendor-ad64e72158.js:24014 start server command: "D:\ParametricAnalysisTool\pat\ruby\bin\ruby.exe" "D:\ParametricAnalysisTool\pat\OpenStudio-server\bin\openstudio_meta" start_local --worker-number=11 --energyplus-exe-path="D:\ParametricAnalysisTool\pat\EnergyPlus\energyplus.exe" --openstudio-exe-path="D:\ParametricAnalysisTool\pat\OpenStudio\bin\openstudio.exe" --ruby-lib-path="D:\ParametricAnalysisTool\pat\OpenStudio\Ruby" --mongo-dir="D:\ParametricAnalysisTool\pat\mongo\bin" --debug "D:\SRTP\Roof\Qiangongyuan Roof R-value" app-77544dda7e.js:8712 Child pid: 13848 app-77544dda7e.js:8723 child exited due to receipt of signal null (exit code 1)
Thank you so much!
