Hi, I'm getting vertex size mismatch for 2 of the walls in my model.
I've tried a few things as mentioned in other posts such as this one but ran into other problems-
- After dividing the surfaces into smaller convex surfaces- this led to an error saying the Subsurface (Door) is bigger than the base surface (which was divided into smaller parts).
- After making the X,Y,Z coordinates of all the vertexes of the problematic surfaces to be the same- this made the surface change size and position weirdly and they went all over the place. I made sure all the coordinates of both surfaces are the same. Perhaps the origin is different for the 2 zones.
- I tried re-intersecting/matching surfaces but didn't help.
Here is the file: https://drive.google.com/file/d/17il1PFSsjvPNQxHkFQwrww-LjXHlsCGT/view?usp=sharing
Any help will be appreciated. Thanks!
