Does anyone know why i'm getting this error when i try to register the plugin?
Is it because i am using Make 2017? Because i see videos of other people using this and it working just fine.
https://youtu.be/WkgQAIaXy78
Thanks
| 1 | initial version |
Thanks
Given the fact that the developer of FloorSpace.js says he doesn't intend to fix the pluenum door issues (documented here) am trying Sketchup but i get this plug-in erorr.
Thanks
Thanks
openstudio_dir = Sketchup.read_default("OpenStudio", "OpenStudioDir")
C:/openstudioapplication-1.0.1
openstudio_modeleditor_rb = File.join(openstudio_dir, "Ruby/openstudio_modeleditor.rb")
C:/openstudioapplication-1.0.1/Ruby/openstudio_modeleditor.rb
load(openstudio_modeleditor_rb)
Error: #<loaderror: 126:="" the="" specified="" module="" could="" not="" be="" found.="" -="" c:="" openstudioapplication-1.0.1="" ruby="" openstudio.so="">
C:/openstudioapplication-1.0.1/Ruby/openstudio.rb:55:in require_relative'
C:/openstudioapplication-1.0.1/Ruby/openstudio.rb:55:in<top (required)>'="" c:="" openstudioapplication-1.0.1="" ruby="" openstudio_modeleditor.rb:67:in="" <code="">require_relative'
C:/openstudioapplication-1.0.1/Ruby/openstudio_modeleditor.rb:67:in<top (required)>'="" <main="">:in load'
<main>:in<main>'
SketchUp:1:in `eval'
Thanks
Does anyone know why i'm getting this error when i try to register the plugin? @macumber
<main>:in<main>'
Thanks
<main>:in<main>'
Thanks
Does anyone know why i'm getting this error when i try to register the plugin? @macumber@macumber
Everytime i try to install the plugin it wants to default to the 2.9 path, but i was able to reset it but it still won't do it right.
<main>:in<main>'
Thanks
