I am trying to view a variety of hourly Output Variables using readvars eso to calibrate my model. The eso output always contains zone temp and humidity (not asked for), which max out my 255 column limit, so I cannot view my selected output variables (unless I select another Zone variable, which integrates itself with each zone temp and humidity column group). Even in this case my 255 max limits the number of zones I can see.
In Open Studio I have turned Possible Output Variables "All Off", ensuring that zone temp and humidity are not selected. However, they always remain a part of the eso output. I've tried this a couple ways with no success. Is this is a default setting that I cannot change? Is there something I've overlooked? Thank you.
