Hi all,
I did an architectural design using Revit 2020, then I created my energy model and I did a system analysis (Annual building energy simulation). I got a report similar to one by Energyplus . where can I found my IDF file who is used by Revit/E+ to create the report?
NB: I'm trying to find a method to create IDF file from Revit without using GBS and then export IDF file. Thank you.
