Can someone tell me why this fails? I have a short 2-minute video link so you can see the configuration. Sorry but i am not allowed to share my model.
https://youtu.be/NTV58LvG5gQ
Thank you.
| 1 | initial version |
Thank you.
[openstudio.model.AvailabilityManagerNightCycle] <2> Object of type 'OS:AvailabilityManager:NightCycle' and named 'AVM Night Cycle 1' does not have a controlThermalZoneList attached
[10:51:46.059534 ERROR] Found error in state 'translator' with message ["C:\Users\jenkins\git\OpenStudio\src\model\AvailabilityManagerNightCycle.cpp@243 : Object of type 'OS:AvailabilityManager:NightCycle' and named 'AVM Night Cycle 1' does not have a controlThermalZoneList attached::/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/model.rb:105:in translateModel'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/model.rb:105:intranslate_to_energyplus'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/jobs/run_translation.rb:72:in perform'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:292:instep'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:234:in run'\n:/openstudio_cli.rb:973:inexecute'\n:/openstudio_cli.rb:763:in execute'\n:/openstudio_cli.rb:1757:in<main>'\neval:149:in eval'\neval:149:inrequire_embedded_absolute'\neval:123:in block in require'\neval:117:ineach'\neval:117:in require'\neval:3:in<main>'"]}
Thank you.
A similar issue was reported here but not resolved: https://unmethours.com/question/35429/availability-manager-night-cycle-zone-list-name/
Thank you.
[10:51:46.059534 ERROR] Found error in state 'translator' with message translateModel'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/model.rb:105:inperform'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:292:instep'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:234:in run'\n:/openstudio_cli.rb:973:inexecute'\n:/openstudio_cli.rb:763:in execute'\n:/openstudio_cli.rb:1757:in<main>'\neval:149:in eval'\neval:149:inrequire_embedded_absolute'\neval:123:in block in require'\neval:117:ineach'\neval:117:in require'\neval:3:in<main>'"]}A similar issue was reported here but not resolved: https://unmethours.com/question/35429/availability-manager-night-cycle-zone-list-name/
Thank you.
| 5 | retagged |
["C:\\Users\\jenkins\\git\\OpenStudio\\src\\model\\AvailabilityManagerNightCycle.cpp@243 : Object of type 'OS:AvailabilityManager:NightCycle' and named 'AVM Night Cycle 1' does not have a controlThermalZoneList attached:
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/model.rb:105:in `translateModel'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/model.rb:105:in `translate_to_energyplus'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/jobs/run_translation.rb:72:in `perform'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:292:in `step'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:234:in `run'
:/openstudio_cli.rb:973:in `execute'
:/openstudio_cli.rb:1757:in `<main>'
eval:149:in `eval'
eval:149:in `require_embedded_absolute'
eval:123:in `block in require'
eval:117:in `each'
eval:117:in `require'
eval:3:in `<main>'"]}
Thank you.
| 6 | retagged |
eval:149:in `eval'
eval:117:in `each'
Thank you.
