Hi,
I am trying to run a 2.80 OS model developed in sketchup 2017.
I receive the following error initially:
" * Severe * RoofCeiling:Detailed="SURFACE 1986", Vertex size mismatch between base surface :SURFACE 1986 and outside boundary surface: SURFACE 1944 * ~~~ * The vertex sizes are 8 for base surface and 4 for outside boundary surface. Please check inputs."
When I edit the osm file (with N++) and remove the last 4 of the 8 extra vertices on surface 1986, I try to reopen the OSM file and get this error:
Error 2
"Model with Version 2.8.0 IDD is not valid to draft strictness level. The collection is INVALID at strictness level 'Draft', because of the errors: Field level data error of type DataType . Error is in an object of type 'OS:Surface', named 'Surface 1986', in field 23. Additional information about the error type: field-level data is of an incorrect type."
I am lost. Please advise on best next steps.
Thanks
