Hello,
I tried to run jEPlus.... but it doesn't work :(
I think I didn't define rvi file
My parameter is
1.infiltration rate [0.1: 0.01: 0.6]
2.setpoint temperature [18: 0.1:32]
I also execute 1000 lhs
Thank you so much!!!!
| 1 | initial version |
Hello,
My parameter is
| 2 | No.2 Revision |
Hello,
I think that's because I didn't define rvi filefile correctly.
Is it right way to define rvi file?
My parameter is
| 3 | No.3 Revision |
Hello,
I think that's because I didn't define rvi file correctly.
or maybe i put parameter name, description, search tag arbitrary..........
i mean i didn't change @@~~ @@ in an IDF file.....
i saw " string must not naturally occur in an IDF file" ...........how can i change it.....?
My parameter is
| 4 | No.4 Revision |
Hello,
( i only changed parameter item on the left side of the picture)
My parameter is
| 5 | No.5 Revision |
Hello,
I tried to run jEPlus.... but it doesn't work again :(
My parameter is
| 6 | retagged |
Hello,
My parameter is
| 7 | retagged |
Hello,
My parameter is
