openstudio_ruby/2.5.5@nrel/stable: WARN: Readline (hence GDBM) will not work on MSVC right now openstudio_ruby/2.5.5@nrel/stable: WARN: Conan LIBFFI will not allow linking right now with MSVC, so temporarilly built it from CMakeLists instead openstudio_ruby/2.5.5@nrel/stable: WARN: Conan GMP isn't supported on MSVC WARN: cpprestsdk/2.10.14@bincrafters/stable: requirement openssl/1.1.1d overridden by your conanfile to openssl/1.1.0l WARN: websocketpp/0.8.1@bincrafters/stable: requirement openssl/1.1.1d overridden by cpprestsdk/2.10.14@bincrafters/stable to openssl/1.1.0l bzip2/1.0.8: WARN: Can't update, no package in remote fmt/6.0.0: WARN: Package is corrupted, removing folder: D:\MyData\sahoo.ritesh.conan\data\fmt\6.0.0__\package\e0a02d496bbb652b6295152dfce0d3937acc0b56 fmt/6.0.0: WARN: Build folder is dirty, removing it: D:\MyData\sahoo.ritesh.conan\data\fmt\6.0.0__\build\e0a02d496bbb652b6295152dfce0d3937acc0b56 fmt/6.0.0: ERROR: Package 'e0a02d496bbb652b6295152dfce0d3937acc0b56' build faile d fmt/6.0.0: WARN: Build folder D:\MyData\sahoo.ritesh.conan\data\fmt\6.0.0__\build\e0a02d496bbb652b6295152dfce0d3937acc0b56 ERROR: fmt/6.0.0: Error in build() method, line 61 cmake.build() ConanException: Error 1 while executing cmake --build D:\MyData\sahoo.ritesh.conan\data\fmt\6.0.0__\build\e0a02d496bbb652b6295152dfce0d3937acc0b56\build_subfolder --config Release -- /m:12 /verbosity:minimal
CMake Error at buildcode/conan.cmake:402 (message): Conan install failed='1' Call Stack (most recent call first): buildcode/conan.cmake:492 (conan_cmake_install) ConanInstall.cmake:55 (conan_cmake_run) CMakeLists.txt:38 (include)
Configuring incomplete, errors occurred! See also "D:/BEMS/OpenStudioApplication-develop/buildcode/CMakeFiles/CMakeOutput.log".
