I'm experiencing installment difficulties with the latest OS application (v1.0.0). After the installation is finalized I tried to run OpenStudio. But here is what I get, right before the programs starts:
Before this version, I was using the v2.9 then I installed it to go with the latest version. Since I didn't know anything about the Application release transition, I went with v3.0 which did not contain OS Application ([https://unmethours.com/question/44408/cant-find-openstudioexe-on-new-version-installation-v30/])
As I mentioned above, after removing the SDK version and installing the Application version (which I repeated several times!!) I couldn't run the program. I'm aware that there are some other related questions. But I couldn't find the answer to my problem.
