I'm fairly new to EnergyPlus and this kind of simulations but I am currently trying to setup a small simulation. I have a small building/room with a baseboard heater, a low temperature radiant system and also an air terminal. The simulation runs but I get 2 errors and a lot of warnings. The errors are no problem, I know how to handle them but I have no clue how to get rid of the warning. The warnings are regarding the heat exchanger and cooling tower I used. I tried using different input values but I keep getting this warnings. Can anyone help me? How do I get rid of these warnings?
************* ** Warning ** HeatExchanger:AirToAir:SensibleAndLatent "RLT HX": Average air volume flow rate is <50% or >130% warning continues. Air flow rate ratio statistics follow.
************* ** ~~~ ** This error occurred 147710 total times;
************* ** ~~~ ** during Warmup 0 times;
************* ** ~~~ ** during Sizing 0 times.
************* ** ~~~ ** Max=1.025100E-002 Min=9.729411E-003
************* ** Warning ** CoolingTower:VariableSpeed "TURM" - Tower range temperature is out of range error continues...
************* ** ~~~ ** This error occurred 5109 total times;
************* ** ~~~ ** Max=1.03331 Min=4.109782E-005
************* ** Warning ** CoolingTower:VariableSpeed "TURM" - Cooling tower air flow rate ratio calculation failed error continues.
************* ** ~~~ ** This error occurred 271 total times;
