I'm looking into using scripting to run the analysis on an OSServer. I followed JS files and been able to boil it down to this line which runs the analysis. I noticed there're log after every command and all of that should be stored in a file somewhere. For that line specifically, it's followed by if (vm.Message.showDebug()) vm.$log.debug('FULL run_analysis command: ', full_command);
My questions are:
where can I find the log file which shows the full_command (I installed PAT as part of the latest 2.9 OS installer)
What's the best way to use scripting to automate the workflow and bypass PAT?
2.1 Create project Json/Zip
2.2 Run analysis on already started server
Thanks
