Warning * SizeWaterCoil: Potential issue with equipment sizing for Coil:Heating:Water F1-Z1 REHEAT COIL * ~~~ * ...Rated Total Heating Capacity = 0.00 [W] * ~~~ * ...Air flow rate used for sizing = 0.00000 [m3/s] * ~~~ * ...Plant loop temperature difference = 11.00 [C] * Warning * The design coil load is zero for Coil:Heating:Water F1-Z1 REHEAT COIL * ~~~ * The autosize value for maximum water flow rate is zero * ~~~ * To change this, input a value for UA, change the heating design day, or raise the * ~~~ * system heating design supply air temperature. Also check to make sure the Preheat * ~~~ * Design Temperature is not the same as the Central Heating Design Supply Air Temperature. *** SizeHVACSingleDuct: Potential issue with equipment sizing for AirTerminal:SingleDuct:VAV:Reheat = "F2-Z1 VAV REHEAT". * ~~~ * User-Specified Minimum Cooling Air Flow Rate of 0.40000 [m3/s] * ~~~ * differs from Design Size Minimum Cooling Air Flow Rate of 0.00000 [m3/s] * ~~~ * This may, or may not, indicate mismatched component sizes. * ~~~ * Verify that the value entered is intended and is consistent with other components. * Warning * SizeWaterCoil: Potential issue with equipment sizing for Coil:Heating:Water F2-Z1 REHEAT COIL * ~~~ * ...Rated Total Heating Capacity = 0.00 [W] * ~~~ * ...Air flow rate used for sizing = 0.00000 [m3/s] * ~~~ * ...Plant loop temperature difference = 11.00 [C] * Warning * The design coil load is zero for Coil:Heating:Water F2-Z1 REHEAT COIL * ~~~ * The autosize value for maximum water flow rate is zero * ~~~ * To change this, input a value for UA, change the heating design day, or raise the * ~~~ * system heating design supply air temperature. Also check to make sure the Preheat * ~~~ * Design Temperature is not the same as the Central Heating Design Supply Air Temperature. *** SizeHVACSingleDuct: Potential issue with equipment sizing for AirTerminal:SingleDuct:VAV:Reheat = "F3-Z1 VAV REHEAT". * ~~~ * User-Specified Minimum Cooling Air Flow Rate of 0.40000 [m3/s] * ~~~ * differs from Design Size Minimum Cooling Air Flow Rate of 0.00000 [m3/s] * ~~~ * This may, or may not, indicate mismatched component sizes. * ~~~ * Verify that the value entered is intended and is consistent with other components. * Warning * SizeWaterCoil: Potential issue with equipment sizing for Coil:Heating:Water F3-Z1 REHEAT COIL * ~~~ * ...Rated Total Heating Capacity = 0.00 [W] * ~~~ * ...Air flow rate used for sizing = 0.00000 [m3/s] * ~~~ * ...Plant loop temperature difference = 11.00 [C] * Warning * The design coil load is zero for Coil:Heating:Water F3-Z1 REHEAT COIL * ~~~ * The autosize value for maximum water flow rate is zero * ~~~ * To change this, input a value for UA, change the heating design day, or raise the * ~~~ * system heating design supply air temperature. Also check to make sure the Preheat * ~~~ * Design Temperature is not the same as the Central Heating Design Supply Air Temperature. *** SizeHVACSingleDuct: Potential issue with equipment sizing for AirTerminal:SingleDuct:VAV:Reheat = "F4-Z1 VAV REHEAT". * ~~~ * User-Specified Minimum Cooling Air Flow Rate of 0.40000 [m3/s] * ~~~ * differs from Design Size Minimum Cooling Air Flow Rate of 0.00000 [m3/s] * ~~~ * This may, or may not, indicate mismatched component sizes. * ~~~ * Verify that the value entered is intended and is consistent with other components. * Warning * SizeWaterCoil: Potential issue with equipment sizing for Coil:Heating:Water F4-Z1 REHEAT COIL * ~~~ * ...Rated Total Heating Capacity = 0.00 [W] * ~~~ * ...Air flow rate used for sizing = 0.00000 [m3/s] * ~~~ * ...Plant loop temperature difference = 11.00 [C] * Warning ** The design coil load is zero for Coil:Heating:Water F4-Z1 REHEAT COIL
