I am trying to create a simple load model (no annual simulation) in OpenStudio and, frustratingly, the tabular outputs don't seem to report peak cooling load. I don't have many data-points, but, in my experience, this has only been a problem with models that I've initially created in OpenStudio. The following three images are:
- The reported cooling load (note: this does not seem to get past the the Jan 21st sizing day for some reason)
- The reported heating load
- An ESO plot of cooling/heating load for each timestep on the two simulated design days
This is a simple model which uses ZoneHVAC:IdealLoadsAirSystem
and is run for a single heating design day and a single cooling design day pulled from a DDY file.
