Hi. I am working on energy modeling with Trane Trace 700, so I have proposed model and baseline model. Based on the code, I am using the minimum OA for thermal zones in both models with same amount. However, the result from Trane Trace shows me different outdoor air amount in hourly. The total amount of OA is same in Airflow report however, in hour Ventilation chart shows me dramatic difference between baseline model and proposed model. How that hourly OA amount is calculated? Is that space peak? or coil peak?
Thank you.
