Is there a drawing anywhere corresponding to an IDF of how all the stuff in the AirFlowNetwork objects are linked together and where the nodes are? I have a working AirLoop that I'm trying to add AirFlowNetwork objects for modeling thermal losses and leaks from ducts in the attic. I've been trying to use the AirflowNetwork_Attic_Duct.idf example file as a template, but I have not gotten anything to work. I looked in the IO Ref and the comments in the top of a couple energyplus example files, but I haven't found anything.
EDIT
In the AirflowNetwork_Attic_Duct.idf example file in particular, there is a single node in the AirLoop that is referenced by two different AFN nodes, which are then referenced by AirflowNetwork:Distribution:Linkage objects.
AirflowNetwork:Distribution:Node,
MainInletNode, !- Name
Air Loop Inlet Node, !- Component Name or Node Name
Other, !- Component Object Type or Node Type
1; !- Node Height {m}
FanInletNode, !- Name
AirflowNetwork:Distribution:Linkage,
SystemReturnLink, !- Name
MainReturnNode, !- Node 1 Name
MainInletNode, !- Node 2 Name
AirLoopReturn; !- Component Name
SystemInletLink, !- Name
MainInletNode, !- Node 1 Name
FanInletNode, !- Node 2 Name
MainReturn, !- Component Name
Occupied Thermal Zone; !- Thermal Zone Name
SupplyFanLink, !- Name
FanInletNode, !- Node 1 Name
FanOutletNode, !- Node 2 Name
Supply Fan 1; !- Component Name
There are other nodes and connections in the AirflowNetwork_Attic_Duct.idf example file that I'm not really sure what they mean. That's why having a drawing of how things are connected in the AirflowNetwork_Attic_Duct.idf would be really useful for learning how to use the AirFlowNetwork. Something like a diagram with the node names labeled in the AirLoop and AirFlowNetwork, hand drawn, and scanned would be really useful.
POST SCRIPT
There seems to be some confusion about creation of a diagram to learn how to make an AirFlowNetwork in EnergyPlus. I don't need to be able to visualize EVERY AirFlowNetwork connections in any arbitrary IDF file, I just need ONE example diagram for ONE IDF file. For example, here is a nice diagram of an airloop from the IO Ref. There is no such example diagram for making ducts in the AirFlowNetwork in the IO Ref.
I will now attempt to make my own drawing for the AirFlowNetwork in the AirflowNetwork_Attic_Duct.idf example file using a piece of paper, a pencil, and potentially, an eraser. WARNING: TO ANYONE WHO WANTS A CORRECT VISUALIZATION of the AirFlowNetwork from the AirflowNetwork_Attic_Duct.idf example file, THIS DRAWING IS PROBABLY WRONG SINCE I DON'T KNOW HOW TO CORRECTLY MAKE AN AirFlowNetwork in EnergyPlus.
Here is a picture of the AirLoop with equipment and node names for reference in the AirFlowNetwork digram.
Here is a diagram of the AirFlowNetwork. TO BE ADDEDAirFlowNetwork.
