Hi I noticed that as the openstudio model gets bigger, it takes longer to load the "apply measure now" window. In my case it takes 10+ min to open that window and another 15min+ to show up the options after you select the measure in the window.
What's affecting the loading speed for openstudio measures? model size, number of measures in the library, etc?
And is there any way to speed up this process, or apply measure outside of the openstudio interface if that helps?
