I am working on a sngle office room model using EnergyPlus. The simulation results showed that more heat is transferred though roof than walls and glazing.
But don't know which side wall will transfer more heat. According to the simulation results, east sided wall will transfer more heat than others but studied in literature more heat is transferring through south sided wall.
Now I am confusing what I have to do for that....
Still it is showing Zero error and warning.
If anyone know about how much heat will be transfered through each side of building envelope? Which side wall will transfer higher heat?
I need help in this regard.
