Hi everyone,
I'm getting the following error when I run my model:
* Severe * Invalid Actuated Component Unique Name =189.1-2009 - OFFICE - OPENOFFICE - CZ4-8 LIGHTS DEFINITION * ~~~ * Entered in EnergyManagementSystem:Actuator=ENERGY_MANAGEMENT_SYSTEM_ACTUATOR_1 * ~~~ * Component Unique key name not found * ~~~ * Use Output:EnergyManagementSystem object to create .edd file for valid component names. * Severe * Invalid Actuated Component Control Type =ELECTRIC POWER LEVEL * ~~~ * Entered in EnergyManagementSystem:Actuator=ENERGY_MANAGEMENT_SYSTEM_ACTUATOR_1 * ~~~ * Control Type not found * ~~~ * Use Output:EnergyManagementSystem object to create .edd file for valid component control types.
All I did was change W/m2 intensity for that definition. I even tried changing it back to what the default definition is but it still failed.
Any help is appreciated! Thanks so much!
