DX:SingleSpeed Heating Coil - Heating Capacity
Hi, I have a building model with Packaged Terminal Heat Pump. I want to use EMS to change the DX cooling / heating coil capacity. In the .edd file I found the Actuator for the cooling coil total cooling capacity:
"EnergyManagementSystem:Actuator Available,1LEVEL1:T3WEST PTHP DX COOLING COIL,Coil:Cooling:DX:SingleSpeed,Autosized Rated Total Cooling Capacity,[W]"
But I can't find the equivalent Actuator for the heating coil. Does anyone know what is the equivalent for heating coil? Or how to change the heating capacity?
Thanks.
