Jeplus during application and give error: "* Severe *, or;Expected on this line IP: IDF Line~3 ##set1 T32 25" However, I checked that there was no problem with the symbol. I checked the file "eplusout. Audit", which indicated that "Echo of input lines is off. May be activated by setting the environmental variable DISPLAYINPUTINAUDIT=YES".
