Hello everyone,
When dynamic daylight simulation is performed through phase reuse ( view-matrix), a piece of glass is divided into five pieces and the simulation is repeated using the V matrix. Is the room.rad/room.oct file the same when reuse v-matrix?
Why is the size of the hole of a wall equal to the size of the overall window instead of a single piece of glass when the V matrix is reused?
The light from the window to the designated points in the room has been reflected many times, such as "-ab 1024". When the simulation is performed separately, the place where there is glass is now gone, will not affect the accuracy of the results?
